Spart
Yes, don't consider a GL-5 in any weight for this or nearly any other manual transmission. They usually contain sulfur-phosphorus extreme pressure (EP) additive, which is great for a hypoid gear in a ring/pinion differential. Our cars on the other hand, being FWD only, do not have hypoid gears in the diff and thus have no need for the EP additive. Additionally (and most concerningly) that additive is corrosive to the yellow metals in your synchros, and possibly also shift forks, bushings, and thrust bearings depending on the particular trans.My understanding is that GL5 will damage bronze parts
"Using GL5 gear oil, which is typically intended for differentials, could harm the transmission, especially if it has parts sensitive to the additives in GL5, such as synchronizers or other internal components."
GL-5 is what I put in the front and rear diffs of my Tacoma. The gearbox gets a separate GL-4 fluid, even though it's similar in viscosity to the diff fluid and I could save a few bucks by consolidating consumables.
