Clutch Master Cylinder bypass
atlcivic
E
Atlanta
BMW 1M
Does anyone have experience with this kit that can share their experience?
https://www.precisionautocanada.com/produit/15635-pac-cmc-fl5
I’m also looking at the sirimoto bypass kit but am thinking this direct line to the slave cylinder seems more efficient and eliminates a lot of unnecessary connection points. Wunderladen says they’re working on one also but won’t be available until Q1 2026.
Spart
2025 Integra Type S
I installed the Sirimoto version. I agree that a single line would be ideal, but the Sirimoto has the benefit of looking OEM if you're under warranty.
Either will have the same effect though.
If you're deleting your CMC damper, you should also delete your CDV valve.
atlcivic
E
Atlanta
BMW 1M
Appreciate the feedback. If the sirimoto has the same effect I might just go with that as I’ve already bought a stainless clutch line. Plan to do clutch delay valve delete at the same time as well.
Spart
2025 Integra Type S
