fastSI
Trois-Rivieres,Quebec,Canada
Civic Type-R 2018 CW #13019,SI 2022 RR
I still had my PRL Short Ram from my 2020 SI so wanted to see if everything would fit
Everything fits #1,a little tight where the turbo inlet is ,but fearly easy to fit..
The only thing is the bracket that comes with the 10th gen does not fit...
You can leave it like that,but i made my own little bracket just to be safe..also i
left a part of the oem filter inlet to let the air get under the filter..
Maf sensors plugs right in... ***EDIT *** All 10th gen SI and all 11th gen 1.5T Motors runs the SAME MAF*** OEM PART # 37980-5BA-A01
No check engine and you can really hear the turbo spooling
11th Gen Honda Civic Civic SI 2022 PRL SHORT RAM INSTALL 20220424_162849
11th Gen Honda Civic Civic SI 2022 PRL SHORT RAM INSTALL 20220424_162900
11th Gen Honda Civic Civic SI 2022 PRL SHORT RAM INSTALL 20220424_162927
11th Gen Honda Civic Civic SI 2022 PRL SHORT RAM INSTALL 20220424_162954
11th Gen Honda Civic Civic SI 2022 PRL SHORT RAM INSTALL 20220424_163007
kanav
Kanav
Toronto, ON
2022 Civic Si Black
Do you have the ability to monitor your IAT temps and get back to us with the numbers after a few pulls/sitting in traffic?
Gotch
Rob
2022 Si Blaze Orange
Do you have a Tuner to monitor A/F Ratios?
MAFS are different from 10th gen to 11th... just because it fits doesn't mean you should run it, CEL or not.
Have you reached out to PRL to see if that MAF works for 11th gen?
fastSI
fastSI
I work in the parts department for Honda and 10th gen and 11th gen SI as the same Maf..
part # 37980-5BA-A01 ,so no problems...( i did all my research before installing it,just to be sure)
BTW All SI 17-20 and all 1.5T 2022 as the same maf...#37980-5BA-A01
