Blow Off Valve - Boomba Racing
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
www.boombaracing.com
2017 Civic Sport, 2018 Civic Type-R, 2010 Civic SI, 2015 Civic SI,
Boomba Racing is very excited to bring you our Blow Off Valve for the Tenth Generation Civic!
Available here: http://www.boombaracing.com/2016-honda-civic-blow-off-valve-1-5-turbo/
Installation guide: http://www.boombaracing.com/content/CIVIC X - BLOW OFF VALVE MANUAL.pdf
No aftermarket tuning required. Will work on stock tune or aftermarket tunes. This piece does not throw any check engine lights, does not cause any turbo lag, and does not make the vehicle stutter between shifts.
Replace your factory BPV which is made of cheap rubber and plastic and known to rip and leak boost. This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 100psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
Installation is simple (direct replacement to stock) and all necessary hardware is included.
Available in your choice of color: Black, Blue, Red, or Pure Aluminum
11th Gen Honda Civic Blow Off Valve - Boomba Racing 32461556872_83a0eac6f1_k
11th Gen Honda Civic Blow Off Valve - Boomba Racing 32574558106_53bec4356e_k
dallasjhawk
Arlington, TX
2016 Civic EX-T, 2004 Acura TSX
Well that looks simple enough to install. "sneeze" away
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Sweet! Are you offering any discounts for forum members?
We are not offering any discounts right now but, we offer free shipping on this product anywhere in the US.
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Cannot wait to see how this performs after having been on some cars for several months :) I want one for sure but its a later down the list item and I want to see how ppl like it after a bit and how everything performs :)
-R
We can't wait to see some customer feedback in here!
kshawn
Matthew
Maine
2017 Civic SI
Just ordered :)
kshawn
Matthew
Maine
2017 Civic SI
dallasjhawk
Arlington, TX
dallasjhawk
Arlington, TX
