Integra23
Not that I could feel. I ended up pulling it when I replaced my fuel injectors.Did you notice a difference in any way with handling or braking with the 27won?
Thanks for letting me know. I notice a lot of them seem to be going up for sale on people that are still keeping the car.Not that I could feel. I ended up pulling it when I replaced my fuel injectors.
I switched from the Ultra Racing Strut Bar to the 27WON some time ago. Did my usual route to test out handling and wasn't any more impressed because it felt the same as the Ultra Racing bar that was cheaper...I then hit the brakes, applying the usual pressure I was used to and damn near triggered ABS ?Did you notice a difference in any way with handling or braking with the 27won?
Do you have the brake brace or did you notice the difference using just the strut bar?I switched from the Ultra Racing Strut Bar to the 27WON some time ago. Did my usual route to test out handling and wasn't any more impressed because it felt the same as the Ultra Racing bar that was cheaper...I then hit the brakes, applying the usual pressure I was used to and damn near triggered ABS ?
The pedal felt twice as tight! Tried again at lower and higher speeds, same thing, the brake pedal response is more instant and at the top of the brake pedal.
I'm a believer, it really does work.
Strut Bar + Brake BraceDo you have the brake brace or did you notice the difference using just the strut bar?
