AEM 16-17 Honda Civic 1.5L Gunmetal Intercooler Charge Pipe Kit
kseriesparts
Colorado
  • Increases horsepower and acceleration
  • Allows for the use of after-market bypass or blow-off valves
  • Low restriction aluminum tubing
  • Easy to install using commonly available tools
  • AEM Lifetime Limited Warranty
  • Goes well with AEM 21-798C Cold Air Intake System
16-17 Honda Civic 1.5L Base and Si. Fits both versions
The AEM 26-3003C Intercooler Charge Pipe Kit is a free-flowing, mandrel-bent aluminum tube designed to replace the restrictive factory intercooler piping on specific turbo charged Honda Civic models. The AEM charge pipe has been engineered to reduce turbo charged air pressure loss as well as dramatically increase air flow from the intercooler to the engine. The specialized aerodynamic tube design produces a noticeable horsepower and acceleration gain from your engine. This cold-side charge pipe has two provisions for 1/8 inch NPT ports for you to optionally add either a water-methanol injection or a nitrous oxide modification. The AEM intercooler piping is constructed from lightweight aluminum with a durable gunmetal gray powder coated finish. For additional horsepower gains and improved engine compartment aesthetics, the AEM 21-798C Cold Air Intake System can be installed into your vehicle as well. The charge pipe kit is easy to install with commonly available tools and it is backed by AEM's Lifetime Limited Warranty.
11th Gen Honda Civic AEM 16-17 Honda Civic 1.5L Gunmetal Intercooler Charge Pipe Kit cat_specifications
AEM 26-3003C Product Specifications
Estimated Horsepower Gain 12 HP @ 2900 RPM
California Restricted Not legal for sale or use in California
Color Gunmetal Gray
Material Used Aluminum
Package Contents 1 Intercooler Pipe
Product Box Height 12.25 in (311 mm)
Product Box Length 20.25 in (514 mm)
Product Box Width 12.25 in (311 mm)
Product Style AEM Intercooler Pipe
Street Legal In All US States No
TUV Approved (Europe) No
Weight 7.5 lb (3.4 kg)
https://www.kseriesparts.com/cr/AEI-26-3003C.html
11th Gen Honda Civic AEM 16-17 Honda Civic 1.5L Gunmetal Intercooler Charge Pipe Kit 26-3003C_241x550
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
