TimeRacer
Trying to find a scan tool that supports ABS bleeding with our cars. I know it's not critically necessary to do when you bleed the brakes, but want to have the option if a normal bleed doesn't do the trick. I bought a Launch x431 Creader and it doesn't appear to support ABS bleeding on the current software though it can actuate the ABS module. Also, can actuate the maintenance mode for the parking brake. Anyone have a scanner recommendation that can initiate the ABS bleed mode?
