27WON Performance Big Brake Kit Launches for the Honda Civic
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Hey guys,
The formal release of our Big Brake Kit for the Honda Civic is now available. You can check out our blog covering the details here. https://www.27won.com/blog/27won-performance-big-brake-kit-launches-for-the-honda-civic
As with all of our products I'll be working on a product video to add to the listing to give you guys a further breakdown on the kit.
This kit has been on the track a handful of times and been pushed to the limits to ensure it works. No ABS or traction lights come from the upgrade. Brake bias is not upset from front to rear, and we designed it so the front caliper is able to accept a wide range of performance pads from various manufacturers.
In regards to wheel fitment, we made it easy and a have a wheel template guide that you can download from our site and put on your wheel ahead of time so you know what you have to do. You can print your copy here
https://store.27won.com/_27Won/27Wo...ke_Kit/FC1-3-413-BBK-Wheel-Fitment-Cutout.pdf
We hope you guys find this as a good solution for the chassis as much as we did.
I have reason to believe this would also fit the Accords and CRV but have not had the chance to fit one on. So if your local and have a new Accord or CRV drop us a line so we can check it out.
Comment and questions below my friends.
11th Gen Honda Civic 27WON Performance Big Brake Kit Launches for the Honda Civic honda-civic-si-big-brake-packag
11th Gen Honda Civic 27WON Performance Big Brake Kit Launches for the Honda Civic honda-civic-si-bbk
Scarlet
Shawn
Caledonia, WI
2001 Civic LX Sedan - 1998 Civic Hatch TBD Turbo Something - 2014 Honda Ruckus - 2017 Civic Si Coupe
What's the smallest wheel you can fit around these??
Scarlet
Shawn
Caledonia, WI
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
17" is what we recommend. You can squeeze a 16" if the concave is right, but I don't suggest it.
Scarlet
Shawn
Caledonia, WI
"think" and "hear"? You wouldn't be spreading bias "opinions" I hope, would look terrible as a moderator if you are..
"Big Brake Kit"
I think someone else has a small brake kit available but I hear it's not very safe for the street.
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
Can always go with the S2000 rotors and the DC5 Brembos from the Integra Type R.
Those are smaller than stock Si.
360glitch
Moderator
2017 Si, 2019 Accord, 2023 Type R
One could likely argue that if I had a bias it would be for the small brake kit I mentioned, not against it. I was told by the company owner in a private conversation that it was not suitable for street use, simple as that. Regardless, if this conversation needs to be continued it should be done so elsewhere, outside of this post within a sponsor’s forum. My apologizes for derailing the post to begin with.
Feel free to contact me within another forum section or via PM with any other questions regarding non 27Won products or me being the most terrible moderator on the site.
blinkz0rz
Jrod
Chicagoland
2018 FC1 Civic Si, 1997 Dodge Dakota, 1972 Plymouth Roadrunner 440, 2010 JKU Jeep Wrangler
Does this kit fit OEM Si wheels, or does it need a spacer too?
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
You would need a spacer. But we made it super easy to figure out. We have a wheel template fitment guide on our website. Designed to help you figure out how much clearance you have.
bakerjal
Jordan
JBPHH, HI
2017 Si Coupe
Is there any way to know what specs you need on wheels to need no spacers? I haven't bought wheels yet, but I'd like to not have to use spacers.
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
We can't give direct specs has the design of every wheel is so different. Two wheels with identical specs might fit differently because of the concave or design pattern. However we do have the wheel template so that you can check it amongst wheels if you are able to get your hands on some to fit. You can download that for free off of our website here.
