What are some of the advantages moving from 19" wheels to 18"?
phatjoe
VJ
Austin, Texas
Toyota Tundra TRD Pro
Hi,
I've noticed that a few folks have switched from 19" wheels to 18". I understand that one benefit of the 18" wheels is the larger sidewall, which provides a softer ride. Are there other advantages to using 18" wheels?
Increased sidewall height helps if you encounter potholes. Probably a good option in snow country.
As far as ride goes, the ITS damper module softens the ride and can be adjusted with the touch of a button.
qingcong
North Carolina
2024 FL5, 2013 Si, 1991 NSX
Hi,
More tire options and tires are cheaper for 18".
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
More tire options, cheaper tires, better ride, lot of wheel selections.
-Josh
