Stock wheel measurements? (those with aftermarket wheels please measure)
yargk
SF bay area
'18 Civic Type R, '16 GT4, '19 GSW 4motion 6mt
What is the exact inner diameter of the wheel at the inside of the inner lip (barrel diameter on the inboard side)?
What is the weight of the stock wheel?
Thanks
surftheweb
Indiana
Civic
In the other thread someone mentioned that the stock wheel/tire set weighed in at 204.2 lb.
surftheweb
Indiana
Civic
If someone is able to measure the stock FL5 wheels, I would also like to know the diameter of the lug hole size measurement in the wheel to see if my existing wheel lock key will fit in there or not. Thanks!
System Motorsports
Thomson
Thomson
Hayward
Black (CBP) FK8 Civic Type R,
Lug hole size should be ~14-15mm as the studs are M14x1.5.
OE wheel spec should be 19x9.5 +~60ET offset.
