KSport Kontrol Pro Damper Coilover System | 36 levels of Adjustable Damping
kseriesparts
Colorado
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
Comes with Pillow Ball Upper Mount for fronts, and Aluminum Hat for rears
Spring Rates:
Front: 7k
Rear: 7k
Ksport Kontrol ProLink
11th Gen Honda Civic KSport Kontrol Pro Damper Coilover System | 36 levels of Adjustable Damping KSPORT10THGEN
Key Features:
    • Made from high quality 6061 aluminum with T6 for increased hardness
    • Compression/Rebound adjustable
    • Adjustable spring perch for height adjustment
    • Adjustable body allowing maximum suspension travel
    • Pillowball top mount with 5 degrees of adjustable camber
    • Monotube high pressure design reduces oil leakage
    • Electroplated body for protection from corrosion and rust
    • One year limited warranty
    • 36 levels of adjustable damping
kseriesparts
kseriesparts
Colorado
Spring Rates:
Front: 7k
Rear: 7k
kseriesparts
kseriesparts
Colorado
Spring Rates:
Front: 7k
Rear: 7k
Key Features:
kseriesparts
kseriesparts
Colorado
Spring Rates:
Front: 7k
Rear: 7k
18 in stock
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
kseriesparts
kseriesparts
Colorado
