procivic
- Jan 29, 2016
- 71
- 691
- 147
- Ventura, California
- Website
- www.procivic.com
- 2022 Civic Si Sedan, Others
To all your Type R owners who want to really make your engine sing, we finally have this in stock!
QUANTTIES ARE EXTREMELY LIMITED RIGHT NOW. If you end up being able to get one from this first round, consider yourself lucky
Product Link: https://www.procivic.com/pages-product_car_part_info/category-70_93/product-3417/index.html
As you may already know, the stock fuel system on FK8 Civic Type R's is the primary bottleneck in making more power. Now, with the Hondata FK8 Civic Type R Fuel System Upgrade, you can finally take your Type R to a new level of power! This fuel system upgrade consists of a unique set of fueling related hardware components that allow about 25% more fuel flow than the stock fuel system. This system is very reliable and engineered to the highest possible specifications for durability and performance!
Key Features:
Key Features:
- Allows your FK8 Civic Type R to exceed the power levels of the performance inhibiting factory fuel system.
- Plug and Play (PnP) upgrade - bolts right on to your other stock fuel system components and can easily be uninstalled if needed.
- Ideal for use with an E85 Flex Fuel system, but also delivers great gains with pump gas. All components have been E85 ethanol tested.
- Tested on multiple Type R Civics for over a full year.
- On a Civic Type R with stock turbo and engine, Hondata was able to run full E85 without any fuel pump limitations! The stock engine torque increased 41% from 333 to 468 lb-ft and power increased 35% from 317 to 428 hp. On a Civic Type R with a turbo upgrade, Hondata has tested to over 500 hp - an amazing 60% power increase over stock. Supporting bolt-on performance parts are required for getting the best power gains.
- Specific flow increases over stock: direct injection pump = 24 %, in-tank pump = 37%, injectors = 20%.
- High flow in-tank low pressure fuel pump.
- High flow low pressure fuel line.
- High flow direct injection high pressure fuel pump.
- High flow high pressure fuel line.
- High flow fuel injectors.
- Precision Hondata FlashPro software control. Multiple free calibrations starting with an increase of 92 lb-ft torque and 59 hp over stock.
