Boostleefl5
Drive a FL5, Does anyone have issues after installing lowering spring and it's not even in both side?. My front right is lower than left front. Is this common?
General items that come up on spring installs, LF and RF are not swapped? Both springs and rubber isolators are sitting on the strut lower perch correctly?Drive a FL5, Does anyone have issues after installing lowering spring and it's not even in both side?. My front right is lower than left front. Is this common?
Thanks for the response. I will keep and eye on it . If it doesn't settle I just have it look at when I get an alignment in the future.General items that come up on spring installs, LF and RF are not swapped? Both springs and rubber isolators are sitting on the strut lower perch correctly?
How uneven is it? Springs take some time to settle (couple hundred) but shouldn't be that uneven L&R after a few miles.
