Downpipe and frontpipe
Vinsi
Vinny
New York
11th gen si
Hello everyone.I was looking to Do a dp and fp upgrade soon.Is it a good idea?I have ktuner 21psi running on it and haven’t had any clutch slippage.Should I purchase a clutch first?
kanav
Kanav
Toronto, ON
2022 Civic Si Black
Clutch slip will probably more have to do with luck and driving style, if you dont full throttle under 3-4k rpm and don’t launch the car you could probably run even the 23psi tune with dp/fp without much issue
The shitty part is luck tho you might just get a bad clutch that is good enough for stock power but slips a little while after tuning the car
Shankmeyster
AZ
23 Type R
Don't bother doing a clutch upgrade until you start noticing problems with your current one. Just going to be spending money you don't need to. Your stock clutch will be fine unless you start trying to do drag launches from every light.
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
Our downpipes are ready now. FP will be later this summer.
