Apple Car Play Audio Lagging
sugarl4nd
Andre
Sugar Land, TX
2023 FL5 CW & 2021 FK8 LE Phoenix Yellow
HELP !!!
Ever since I switch from FK8 to FL5, I experienced Apple Car Play Audio Lagging when playing YouTube or any media. The video and audio is lagging by a few seconds if I use USB cable; and it's even worst lag with Bluetooth/Wireless connection.
Is anyone experienced this lagging ? If you do and manage to resolve it, please share the solution. It will be much appreciated :).
Thank you !
bbrunty15
2014 Accord, 2023 FL5 Civic Type R R-03525
I have been meaning to post about this same issue!!
I will take it a step further, I have noticed that whenever I drive through a very particular location it gets super laggy and will sometimes completely disconnect. I have found that when this happens it wont reconnect until I pass through the area.
My first thought was I must be in an area with high interference but I have driven through other areas of what I would image is high interference too and it doesn't disconnect. I have no idea what causes this. I have only been able to replicated this in one location.
I am using Apple CarPlay wirelessly.
sugarl4nd
sugarl4nd
Andre
Sugar Land, TX
I did try to get into Developer Mode and tried/changed different settings. Making sure that the system has enough memory to handle CarPlay (ie : disabling some memory extensive apps, etc).
None of the combination work, lagging is persistent. The lag always occurred in CarPlay. If I connect ONLY to Bluetooth and use the car as 'Bluetooth Speaker', I don't experience any lag. As soon as I connect with CarPlay, it lag consistently. I hope I make sense.
No luck as of now.
Cable lag is better than wireless, definitely. But still lag which is annoying. I don't have this issue with FK8.
Motpeds
Pedro
Chicago
FL5 - CW
for what its worth, my type R audio lag behaves exactly the same as what i had in my 2.0 Accord. Both seem to have the same "operating system" vs the FK8 which i believe was the last gen OS.
I think its just the way it is, unfortunately.
